02-02-2020 02:52 AM - last edited on 01-16-2024 01:19 AM by ZenBot
02-05-2020 02:37 AM
02-10-2020 12:13 AM
Rocketbalalala posted on 2020/2/5 12:53 Mine doesn't have fingerprint option Waiting for the upcoming updateHi Rocketbalalala, About ASUS ZenFone Max Pro M1 encountered the issue of no fingerprint option after the firmware update to Android 10, in order to keep the security of your data and private information, please use the pin/password/pattern/face recognition to lock screen instead of fingerprint. If the current experience is affecting your normal use, we would recommend you downgrade to Android 9. Please refer below link for download: http://www.asus.com/Phone/ZenFone-Max-Pro-M1/HelpDesk_Download/ http://www.asus.com/support/FAQ/1042349 We apologize for any inconvenience caused and your consideration will be very much appreciated. Thank you for your continued support and patronage.
02-10-2020 01:56 AM
02-10-2020 02:07 AM
slim1.zouawi posted on 2020/2/5 18:37 I forgot to mention that accent color returns to default sometimes after restartHi slim1.zouawi, I forgot to mention that accent color returns to default sometimes after restart > We've checked with relevant teams about this.
02-10-2020 03:31 AM
* The phone vibrates when unlocking with fingerprint , it s annoying and i was not able to remove itIt is normal for android 10 and I find it very useful
