Android 10 for Zenfone Max Pro M2
dodiirwandi40
Model Name: Zenfone Max Pro M2 (ASUS_X01BDA)
Firmware Version: PKQ1.WW Phone-16.2017.2011.105-20210108
Rooted or not: Not Rooted
Frequency of Occurrence:
Aureliannn_ASUS
Hi, according to your question, it is suggest that you manual update your firmware to WW-16.2017.2010.101
If there's any problem occur while using, please manual downgrade to WW-16.2017.2011.105
