Android 10 AOSP on Zenfone max pro m1
c_rakshith
I used about 1 week and I have some reports here.
1.)If I use device continuously it drains battery too fast than Android 9,
2.) On pubg gaming , graphics smooth /balanced - both medium & high setting, the game becomes little bit choppy and gets frame drop too than Android 9.
3.) cant able to configure Jio call app
4.) Sometime some apps getting lag/stucks and it says wait/close.
5.) Home screen google search bar is irritation.
6.) RAM performance is too good works fine
7.) Expected "game mode" while playing games.
8.) Othar than this android 10 AOSP is ok
I believe that you will fix the above in the stable update
Thank you
victor010
Zen Master III
 Hi there, thank you for highlighting the issues. We have made a note of the feedback and will share it with the relevant team.
