08-16-2022
03:52 PM
- last edited on
01-16-2024
01:06 AM
by
ZenBot
11-08-2022 06:50 AM
echang01Hey @echang01,Yessssss I came from an s10e and the navigation button ratio to the screen is super narrow. I also think the big bezel at the bottom doesn't help but if you can have an option to increase the height ratio of the bottom navigation bar, that would make my day!!!
01-16-2023 11:56 AM
I am up to date (dec 5th security update, android 13. Build number is too tedious to type out 🙃). I still experience this issue. This is coming from someone who has been on a full-screen device for 2 years prior using on-screen nav buttons, and never had an issue using them on that device (and ofc didn't back when we had hardware nav bars).
Looking visually, the bar is a bit small, and an option to make it bigger would be useful. But I also think making the area around the icons on the bar within the actuation zone would help. If I'm, say 1/3 of the way off between one button and the adjacent one, it's pretty clear I want the one I'm 2x closer to. That should actuate, but it doesn't. As for vertical distance, I think the dead zone is probably still big, although I'd say a larger bar is also a viable solution for that if there is concern of that resulting in more mistypes/clicks that were intended for the apps and not the bar
11-24-2022 07:11 AM
11-24-2022 07:13 AM
12-03-2022 12:42 AM
