01-16-2023 12:47 AM
Amazing phone, had almost all the Zenfone from the past apart from the 6th I think.
With this, the only issue I've encountered when you open the camera software, it does not run at 120hz at all, perhaps not even 60.
It's all laggy and choppy, not sure what the problem is but it's very noticeable.
01-16-2023 01:38 AM
Check my thread, saved records are laggy too:
01-16-2023 01:54 AM
Thanks.
I don't necessarily have issues with the recording, or picture taking quality, I rather have issue when you just open the camera app... The interface is not running smooth, laggy and not enjoyable using it at all. Not sure what the issue could be, but wondered if others have experienced the same?
01-16-2023 02:39 AM
Yea...same here 🙁
