Zenfone 9 Battery Drain by "Others"
bLackShadow7
Hello,
I have just bought a Zenfone 9 last week and I am having bad battery life. The SOT is roughly 3 to 4 hours. I can see most of the battery is consuming by "Others".
Is it normal?
Model Name: Zenfone 9
Firmware Version: 32.2050.2050.34
I am really disappointed with the battery performance so far.
Thank you
97 REPLIES 97
Madmax999
Rising Star I
Adrian82
I have the same problem too, 43% consumed by Others.
Hapus aja tuh google duo yg ga penting2 amat cui. Disable backround data nya jg yg ga terlalu penting saat make .
Madmax999
Rising Star I
Yang bikin kuras sebenarnya google play service bkin drain . Mesti harua pake module universal gms via magisk biar awet battery nya
pequinois44
je crois que "autre "correspond à la consommation de toutes les applications qui ont été désinstallées récemment
Mansi_ASUS
Hey everyone,
Are you still experiencing the battery drain issue?
Hi, any update on when the developers are going to fix this?
