12-01-2022 02:19 AM
03-05-2023 10:26 AM
Hi @Mansi_ASUS still 10%+ drained every day by this InFamous "other"
Can you provide us an update asap? Issue has bien raised since 2 month it's not acceptable that it's not solved yet. I ll going to do a warranty claim
03-05-2023 06:43 PM
This is getting bad, no fix, it is actually getting worse?! My battery is lasting 4 hours, "Others" is over 50% and I can't force stop anything. I did a backup and wipe on the phone 2 months ago when the problem got this bad and here I am again. Is perhaps the ASUS software just that defective? I have never seen this before. No fix still and it has been months and months?!
03-07-2023 12:06 AM
@Mansi_ASUS Please advise? i might have to move to Samsung
03-07-2023 12:11 AM
Been thinking about trading in the Asus and shipping around myself. I may have no choice in the matter soon.
03-08-2023 01:19 PM
I noticed it depends on something. It doesn't happen always. I don't use phone 24/7 so sometimes I'm albe to use phone for 5-7 days without charging.
However sometimes battery discharges much faster when phone is doing nothing (event in offline mode). Usually it's when I use localization and navigation earlier. I always disable localization when it's not used, so it shouldn't drain battery later.
Also the "Others" percentage is not accurate information especially on phone shutdown and turn on again / reboot.
When I have fast battery drain I usually turns off the phone and turn on it again (localization disabled).
Recently I changed some phone settings, I'll check it now how it works.
Maybe this info will help devs fixing this...
