Zenfone 9 Battery Drain by "Others"
bLackShadow7
Hello,
I have just bought a Zenfone 9 last week and I am having bad battery life. The SOT is roughly 3 to 4 hours. I can see most of the battery is consuming by "Others".
Is it normal?
Model Name: Zenfone 9
Firmware Version: 32.2050.2050.34
I am really disappointed with the battery performance so far.
Thank you
97 REPLIES 97
I've been with ZF9 for just a year and I've been through the A13 beta program and had a similar problem when using the sync app from my smartwatch.
You have to have an app that uses too many resources. Right now the battery usage of "others" is at 10%.
The problem returned on my device again too.
pikashowapk
Depending on your internet connection, the pikachu app download provides high-definition results. Furthermore, the Pika show has actual content from several genres. You can also download your preferred content using the pikashow app -- download.
You may also access numerous platforms, like Netflix, Amazon Prime, Hulu, HBO Go, HBO Now movies, and Hotstar, as well as free movie apps like Tubi TV, Vudu, Pluto TV, and many others, all on a single platform, by utilizing this free live-streaming app called pikashow apk download!
