Zenfone 9 Battery Drain by "Others"
bLackShadow7
Hello,
I have just bought a Zenfone 9 last week and I am having bad battery life. The SOT is roughly 3 to 4 hours. I can see most of the battery is consuming by "Others".
Is it normal?
Model Name: Zenfone 9
Firmware Version: 32.2050.2050.34
I am really disappointed with the battery performance so far.
Thank you
97 REPLIES 97
same here. other with 40% plus battery drain after update to android 13 please provide update! most apps with background restricted data.
Homann
I am having the exact same problem. Used to be fine and last all day now i struggle to get through the day with between 3-4 hours of SoT. Switching back to my pixel
bLackShadow7
Suddenly the phone solve the issue by itself. I am not sure how but the battery backup looks amazing..
I am getting 8-9 hours SOT..
This phone is awesome.. love the experience so far..
Madmax999
Rising Star I
Tips bro . You need disable backround apps or used air frozen
Adrian82
Rising Star I
I have the same problem too, 43% consumed by Others.
