wifi issue on zenfone 9
FGX
Hi I have issue with wifi on zenfone 9
When im using wifi 2.4 ghz i got internet speed around 200mbps
But when im using wifi 5 ghz i got only 100mbps also this phone cannot detect wifi 5Ghz using channel below 149
The range from router to my phone within 5 meters
this issue only happen on zenfone 9
Pls help
Model Name: zenfone 9 8/256
Firmware Version: WW_33.0804.2060.73
Rooted or not: non rooted
Frequency of Occurrence: everytime
rafirasyad
I also can't connect wifi 5ghz on my Zenfone 9 pls help,  I already tried switch wifi 5 and wifi 6 but there is no result. I tried to connect using qr code and it says can't connect.
My Zenfone 9 on Android 13
Hey,
Can you please share the log file?
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “Wi-Fi ”
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
ZenBot
Community Manager
Community Manager
