VoLTE and VoWiFi doesn't work
Popica
Zenfone 9/ Android 13/  33.0804.2060.100/ Romanian operators My sims work on VoLTE and VoWiFi in another phone.
1 ACCEPTED SOLUTION
Accepted Solutions
Zenfone69
1) Try dialling *#*#3642623344#*#*    It won't show anything but WiFi calling will be enabled
2) Go to settings and enable WiFi calling
6 REPLIES 6
Popica
The mobile operators shut down the 3G networks and all calls switch to 2G, until those are shut down as well. Therefore, the voice is not always clear and there are localization problems when calling the emergency services.
Zenfone69
Thank you. It partially worked, but it worked, thanks. However, the team of developers must say why after the restart VoLTE and VoWiFi disappear from the menu and don't work anymore. The code must be entered again and functions are activated.
ulrik77
Hey
I have also try to activate wifi call, dail the code, wifi call is now activatet..
But it works not.
Eny one there have the same problems? Operator says that its activatet ( work on my old Sony espira zx3) but not at Asus zenfone 9...
What to do??
