USB tethering - connection issue
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-08-2022 02:10 AM
Model Name: Asus Zenfone 9 8/256
Firmware Version: WW_32.2050.2050.29
Rooted or not: not rooted
Frequency of Occurrence: Once, but every time the computer / laptop is reset
Hello,
I noticed that when I connect to the network on my computer / laptop using USB tethering, after about 30 minutes it becomes disconnected from it even though USB tethering is still active on the phone. When I repeat the action, i.e. disconnect the phone from the USB cable and plug it back in and turn on USB tethering, everything works normally until the computer / laptop is restarted. Then the situation I described at the beginning arises. Over and over again.
I note right away that this is not a problem with the computer / laptop or USB cable (original), because recently I tested it on my old Asus Zenfone 5 and the computer and the cable are working properly.
Hello,
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-06-2022 01:00 AM
Hey @pendzel_1,
The R&D couldn't recreate the issue and they need a log file from your end.
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can recreate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
You can share the log file via PM. 🙂
2. Enter “.19595+=”
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-13-2022 05:03 AM
@Mansi_ASUS using the newest A12 version USB Tethering worked properly. I'm testing on A13 now.
- « Previous
- 1
- 2
- Next »
