Edge tool doesn't show up
matanyagana
Model Name:zenfone 9
Firmware Version: latest
Rooted or not: no
Frequency of Occurrence: always
APP Name & APP Version (If your issue relates to the app):edge tool
I enabled the edge tool but it doesn't show up at all, like it doesn't exist. It happens to someone else?
6 REPLIES 6
Mattias_ASUS
Hello!
Which settings do you have on the Edge tool?
In Sidebar style you can change the Opacity of the bar, and if it's set to max it will be invisible.
mena_asher
I have the same problem. The edge line dosn't appear.
I changed the style of the line to max. visibility,length,thikness...
matanyagana
Suddenly it does appears to me...i don't know how ....very strange
mena_asher
Hey everybody,
I found a way to rase up the edge bar -
open the settings -> display -> font size
roll to the second screen , where you change the icon size ..
make any change in the icon size
save it >>>>>>>>>>>>>> the wdge bar will appear in the right !!!
i have tried it several times - (restart the phone - the edge bar disappeared - make those steps - the edge bar appear.
