04-10-2023 08:06 AM
After the latest software update, I hide the gesture indicator, which works well, and additionally it lowers the keyboard too, which is perfect. But the issue comes whenever I touch the area around where the gesture indicator used to be, app which uses dark mode, would now blinks a slight green tint, this is super annoying since now the space key on a keyboard now occupies the gesture indicator, and everytime space key is pressed, the screen would blinks.
Model Name: Zenfone 9
Firmware Version: WW_33.0804.2060.113
Rooted or not: NO
Frequency of Occurence: Often, all the time.
Solved! Go to Solution.
04-16-2023 07:54 PM
Can i ask you? What refresh rate that you applied? Maybe you should set to 120hz.
04-13-2023 02:05 AM
Hey @FoHa,
I couldn't recreate this issue on my device however, I have forwarded it to the R&D team.
04-13-2023 07:10 AM
Thanks, it's not very noticable in bright light, but obvious in low light.
And it only happens on app screen, in the video I use google keep, but it can be reproduced as well using other apps like calendar, whatsapp. wechat or firefox when in dark mode.
04-16-2023 07:54 PM
04-16-2023 08:19 PM
Wow, you are right, I have my Refresh Rate set to Auto, the problem's gone after I change my refresh rate to 120Hz. Thanks much.
