Camera Wobbly And Auto Focus Choppy
Biggie
Rising Star I
So after the most recent update ive started to encounter issues with wobbly pictures or videos and sometimes ive even felt the auto focus going crazy, like, CHOPPY. Entire phone just rattled for a sec.
Ive heard about the phone having a focusing issue but ive never encountered it before, only happened now since i updated it yesterday.
Previous FW version that DIDNT have this issue:
WW-33.0804.2060.100
Updated FW version that introduced the issue:
WW-33.0804.2060.113
5 REPLIES 5
Fauzyre
Same with me, but in WW-33.0804.2060.100 version
Im seriously considering flashing a custom Rom onto the phone instead of the OG. The stock rom have so many little bugs that either doesnt get fixed or gets fixed that then break later on.
Custom rom or a custom kernel could probably make the phone soooo much smoother than it is now.
Mansi_ASUS
Hey @Biggie,
Thanks for bringing this issue to out notice. I've forwarded the video to the R&D team.
Mansi_ASUS
Hey @Biggie,
Can you please share a log file?
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
