Bluetooth doesn't automatically reconnect and won't show battery percentage of connected device
jeremy6652
Model Name: ASUS_AI2202 8GB/128GB
Firmware Version: WW_32.2030.2030.26
Rooted or not: No
Frequency of Occurrence: Always
APP Name & APP Version (If your issue relates to the app): -
I have a Bluetooth speaker which usually connects to the last device it was paired with when I power it on. It works on every other phone I've tried but not on the ZenFone 9. Same with the head unit in my car.
The speaker also supports reporting its battery percentage via Bluetooth and this would usually show up in the Bluetooth menu of my old phone or next to the Bluetooth icon in the status bar, it doesn't on the ZenFone.
EDIT: Speaker is a Tribit MAXSound Plus and the headunit is a Kenwood KDC-BT73DAB.
8 REPLIES 8
jeremy6652
I tried @willjoe2442's suggestion again after the update and this time it worked.
The update alone didn't fix it.
Mansi_ASUS
Hey @jeremy6652, does Bluetooth automatically reconnect now?
jeremy6652
Yes, at least with my Bluetooth speaker. Battery percentage also works now.
My car doesn't reliably reconnect automatically yet but it was also very hit or miss on my old phone so that may very well be an issue with the headunit itself.
As I said, the update alone didn't fix it. I had to reset my Bluetooth settings too.
ASUS_Bot
Rising Star II
