Battery overheat
Vion
Zenfone 9 Battery overheat and drop a lot after latest update 33-0804-
Vion
Before the update, the playing mobile legend for 20 minutes will drop 4-5%
After the update. Battery drop from just 20minutes goes up to 7-8%
And phone seems hotter than before update
Mattias_ASUS
Hello!
Just to check, is it the 33.0804.2060.100 update?
Yes correct.
