09-06-2021
09:34 AM
- last edited on
01-16-2024
01:34 AM
by
ZenBot
09-06-2021 12:14 PM
kudloshBecause I know it is. The reason why a kcal implementation was quite easily possible on older models is due to the fact that the screens where quite generic and used the same generic API to control them. This is why modders could simply implement kcal into their kernel and have that feature work. However the display in the zenfone uses samsungs proprietary API that is being controlled over pixelworks software, this means you have no way of taking control over the display at any given time, especially as the software is designed to automaicly make changes based on certain conditions. Unless pixelworks themselves add that feature into the phone, it will not happen.https://zentalk.asus.com/en/discussion/comment/185011#Comment_185011
No, display calibration and tint is not related to the technology. Why would you think it is?
09-08-2021 05:42 PM
DanishbluntAh, I thought you meant OLED as the technology, thanks for explaining (: Anyway, as a customer, I don't want to care about such things. The fact is there are quite a huge differences between displays. Asus should either somehow made the setting available (by negotiating API access?) or made sure all the displays are calibrated properly (better quality control?). I think such problems really should not happen with a flagship phone.https://zentalk.asus.com/en/discussion/comment/185013#Comment_185013
09-08-2021 10:05 PM
kudloshSadly what you're asking for is unresonable. Sadly displays are not created equal, this means it would require ASUS to calibrate each and every panel individually and manually in order to be able to offer consistent experience, which in turn would make the price skyrocket and cause issues when trying to update the firmware as it would not be allowed to overwrite the old calibration.https://zentalk.asus.com/en/discussion/comment/185016#Comment_185016
09-10-2021 10:55 AM
DanishbluntThank you for replying (:https://zentalk.asus.com/en/discussion/comment/185333#Comment_185333
As for setting available, it's unlikely going to happen, it has been suggested multiple times but it doesn't seem pixelworks has any intention of making it happen and since ASUS has to abide to the contract with pixelworks there isn't a single thing they can do about it.
Such problems happen across all flagship phones. If you're sensitive to tint then you should avoid any flagship OLED phone as most have green tint in some way shape or form. Even big companies like Apple and Samsung suffer from green tint issues. There will either be severe black crushing or tinting, a true balance can only be achieved through dynamic calibration which in itself is a massive pain.
09-10-2021 02:09 PM
kudloshLet me clearify since you still don't seem to understand.https://zentalk.asus.com/en/discussion/comment/185364#Comment_185364
I don't think what you are saying is true. Just today I've seen like 5 Samsung flagship phones side by side and also several Xperia 1 and 5 phones. Not only they all had, as far as I can tell, really similar color calibration, they all had similarly good viewing angles (no or only very mild rainbow effect), all much better than Zenfone. I have already returned 3 Zenfones 8 because of unbearable rainbow effect while viewing even from a slight angle or strong green tint.
My point is it can be done. Maybe it would need better quality control, which would mean higher price, but it's a decision, not something inherent to the OLED technology.
But I probably agree that at this price point some corner cuts must have been made. Even though I'd rather have better display and worse SoC, for example (:
