Zenfone 8 freezing and shutting off and WiFi not working
sharmamridul199
Model Name: Zenfone 8z
Firmware Version:  Android 13  33.0210.0210.332
Rooted or not: Not rooted
Frequency of Occurrence: 2 a day atleast
For about 3 days my phone has been freezing and shutting off ( without shutting down written on it i.e. crashing ) on its own and when i turn it on the wifi and hotspot doesn't work atleast. Wifi only works if I turn the device off manually and then turn it on after few minutes
Phone is not heated at that moment though
I have factory reset my phone as well multiple times when this issue started occuring
Falcon_ASUS
@sharmamridul199
According to what you described, please refer to the following FAQ to try to troubleshoot your Wi-Fi problem first.
https://www.asus.com/support/faq/1006657
If the issue persists, I have PM you for confirming your product warranty.
Please check the PM inbox at the top right corner of the screen and kindly provide the requested information.
I have sent you PM with further details
