ZENFONE 8 battery life
gabecka02
What are you guys getting out of the battery?
I'm not super impressed to be fair, fully charging it and by the time I'm back home in the evening is only at 15%.
I have brightness at 80% and display set to 120hz.
Hoping with future updates this can slightly improve?
10 REPLIES 10
dron39
Rising Star II
About the same.
But battery goes from 5% to 1% very slow. And on 1% I can use my phone for about 30 minutes. At least on my phone.
So don't worry too much 🙂
daniel91m
Rising Star II
gabecka02
I have the same as you and I haven't solved the problem for 3 months (battery discharges very quickly when I am outside the range of the wifi network). I'm waiting for android 12.
pio_zen
Rising Star II
Right now I have 41% after 1d 18h (including 8h of airplane mode). 49% used (90% charging limit)
2h30m SOT. Auto brightness. Mainly home wifi. Dual sim. Most app usage - web browsers. Autostart disabled for most apps - only allowed for apps I use regularly.
It seems to be better after last update.
On the last 20% of battery it takes a lot of time to kill the battery.
gabecka02
Thanks for the replies you all! 😊
Will see if any further improvements would be with android 12.
Anyone knows the exact date (not the beta) release?
