Wifi and hotspot are not working
PARIMI
Wifi and hotspot suddenly stopped working. The phone has automatically restarted and after then they are not working. Plz clear the issues with this phone. 30 days back the sim and network have stopped working and now this. Looks like this is what we have to deal with if we buy and asus device.
Irene2_ASUS
Zen Master I
Hi @PARIMI
You could try these trouble shooting steps
1.Check that you are running on the latest firmware version 30.12.112.46
2.Make sure to check on your device if you have the setting "turn off hotspot automatically" function set by default to X minutes instead of 'Never'?
You can check by following these steps;
Settings-> Network & Internet -> Hotspot & tethering -> wi-fi hotspot -> turn off hotspot automatically.
3.If that was set already to never, could you back up your data and perform a factory reset and see if this will solve it.
4.If nothing above solved your issue, then I will recommend you to visit your nearest ASUS Service Center.
