VoLTE and Wifi Calling on Zenfone 8
lukasz_szabelsk
Rising Star II
Hi all,
Does anyone know if we can expect enabling VoLTE and Wifi Calling in european networks? I can only see in settings that icons for these options are available to enable at notification bar:
Also as call quality is quite poor, can we expect some improvement with software updates as enabling HD Voice codecs?
Best,
Lukasz
264 REPLIES 264
AmitGarde
Community Legend II
lukasz.szabelski
Hi all,
Best,
Lukasz
Regarding Volte & wifi calling i can see that it will be enabled slowly as carriers decide to add Zenfone 8 to there support list. Atlast VOLTE & VOWIFI on any carriers totally depends on carrier/ service provider and not ASUS.
you can request your carrier/service provider via emails and helpline to consider Zenfone 8 to there support list of Volte & Vowifi.
Regarding voice call qualtiy there are chances of future adjustments with Voice call quality if there are number of users facing same issue with Zenfone 8.also there is possibility that VOLTE & VOWIFI may improve call quality to some extent. So here you can just wait for future FOTA's
Please share your carrier name for which you want VOLTE & VOWIFI. So that Moderaters may take a look through if Zenfone 8 alredy has it and your device is working as expected or not.
Thanks!
Aryan202
Community Legend I
lukasz.szabelski
Hi all,
Best,
Lukasz
Settings>Network and Internet>Mobile network>Volte
See if you have volte option there
For example I have volte here on my Zenfone 5z
One thing though your carrier has to support volte for the Zenfone 8
If it doesn't right now hopefully Asus will add the support in future as they're gradually expanding their carrier support with updates
AmitGarde
Community Legend II
Aryan202
https://zentalk.asus.com/en/discussion/48261/volte-and-wifi-calling-on-zenfone-8
He had already enabled Volte & Vowifi toggles as you can see above shared screenshot, Enabling it in quick toggles will by default enable it in internal settings. Problem here is his carrier has not yet supported to Zenfone 8. & Hopefully it gets added in future. 🤞
lukasz_szabelsk
Rising Star II
AmitGarde
Thanks!
Thanks @AmitGarde for your response. Much appreciated!
My carrier name is Orange Poland.
Hopefully Voice Call quality will improve in near future. I've read some of first reviews and there are problems with this indeed.
@Aryan202
I don't have these options in mentioned settings area. On my previous mobile (LG G6) was the same until LG released fota upgrade which enabled both options.
