Dirac (Audio Master)
D_IMAN
Rising Star II
Dear developers.
Make in one of the next updates, the ability to disable (either in the application itself, or in the OS settings, or both). Dirac (Audio Master).
Without the use of special third-party programs!
Really needed!
9 REPLIES 9
atanasuzunov
@D_IMAN
Looks very similar to Audio Wizard if not the same. It is below Multimedia option.
Where did you get this Audio Master? Google play?
D_IMAN
Rising Star II
@atanasuzunov I have this item called "Audio Mater".
When I purchased the smartphone, this Audio Master was already present on the smartphone.
I didn't install it from anywhere.
atanasuzunov
@D_IMAN
Ok. Then it looks this is the same app but translated a bit differently.
For me personally, the sound is very good. But I agree that having an option in Quick settings, to disable/enable the dsp, would be useful.
D_IMAN
Rising Star II
@atanasuzunov Let's hope that the developers will not ignore the request, and will make it possible to enable / disable this application!
ASUS_Bot
Rising Star II
