07-29-2021 01:33 AM
07-30-2021 09:35 AM
laci.karaThere must me some bug with phone<>charger negotiations when comes to charging, phone just won't charge in the first port. I have another phone that charges fine on all ports with 18W fast charge its capable of.I used an Acer laptop 45w PD charger, a Dell monitor PD connected (no display support, just charging) and a car QC4 charger (can't remember the brand) and all worked great.
So check with Baseus what is the difference between the two slots
/update, I have checked it. Both type C slots are the same 60+ Watt. Only the total power is limited when more than one slots used, then the first one is limited to 45W the second to 18W but only when both used. So can not be the phone's fault if the first don't work.
07-30-2021 10:07 AM
cytrus224You can have either one faulty it is up to you if You say the phone is.https://zentalk.asus.com/en/discussion/comment/179090#Comment_179090
08-16-2021 05:17 PM
laci.karaI have the exact same model charger from the same manufacturer. I'm also having the exact same problem. The phone only charges about 3-5% if I attempt to charge via USB c. However, it is possible to have it charge normally by repeatedly plugging and unplugging it. It might then proceed to charge as normal during 1 of those tries. I've monitored the charging current, and it works normally until the current hits about 4A and it just stops. This combination suggests that it's some negotiation issue between phone and charger.https://zentalk.asus.com/en/discussion/comment/179094#Comment_179094
08-29-2021 11:58 PM
08-30-2021 03:07 AM
