ASUS Zenfone 8 unable to wifi network and unable to start hotspot
ceejeey
Just today I cant use wifi, it cant detect network and my hotspot it not turning on.
Tried to find some fix but no success. In forums it says that the cause was updating to Android 13 but updated my device a few days ago.
Did try to factory reset and did not help. Caused me huge amount of data to install needed apps. 😭
14 REPLIES 14
Hi @ceejeey
Please check the PM box at the top right corner, we have sent you the messege.
Urossec
All of a sudden, as of today, I cannot use wifi anymore. UI says it is turned on, but no wifi networks are visible (they are working as expected on my other devices). Was there an update that caused this bug? Let me know what info I can provide to help you troubleshoot this issue. Data transfer (via sim) still works as expected.
I am also waiting for the local support to reach me. If there is any new info I will post a reply here so anyone can see.
Hi @ceejeey
I have PM you to confirm about the repair details,
Please check the top right corner and details requested in the PM inbox.
Hi @Urossec
according to your problem, please refer to the following FAQ to try to troubleshoot your Wi-Fi problem first.
 https://www.asus.com/support/faq/1006657/
Also, I have PM you for confirming Wi-Fi issue details.
Could you please check the PM inbox at the top right corner of the screen and kindly provide the requested information?
