Android 12 (. 107) screen brightness problem
slide84
Same problem as this thread (https://zentalk.asus.com/en/discussion/56396/problems-with-android-12) with latest available release (. 107) and after factory reset.
Problem is the screen remains at low brightness level even with lots of ambient light and despite the toggle showing >80%.
5 REPLIES 5
Mekanin
Same here, my zenfone 8 screen is too dim/dark after android 12 update
djstf
Yes I have this too, it can take a lot longer to find the correct brightness when going outside.
Mekanin
Dear @Irene2_ASUS Maybe put this issue to the next fix or update patch. It's really annoying when ZF8 have a beautiful super amoled screen (A11, before update) but now the brightness is too dark after android 12 update.
Thanks
StealthRequiem
Rising Star I
I have a similar issue where the brightness will take a while to adjust to daylight. For several seconds it is too dim, but it does eventually catch up. It is slower to adjust in Android 12.
