10-02-2020 12:54 AM - last edited on 01-16-2024 01:06 AM by ZenBot
10-02-2020 07:14 AM
10-02-2020 07:16 AM
10-07-2020 02:13 AM
Charles RollonWe haven't made it worse. Based on your description is sounds like you had the beauty filter active on the previous fw. Could be that it got deactivated during the upgrade. So please turn it on again and set your desired smoothness 😉@Tagion Tha KS! I know it's not asus fault. I am saying the camera quality became bad when it was good in the beginning.
10-07-2020 10:33 PM
10-08-2020 12:39 AM
laurent.francois.elieother apps use googles camera 2 api to communicate with the camera which is quite limited. I personally always take the picture/video using our own app and then import that in the app I want to useHi, the solution is to set the beauty mode ON ( level 1 if you want a natural aspect ).
One real issue with this device is that third party apps (instagram, WhatsApp, snapchat,...) cannot use the full camera potential out of it.
For some reason Asus makes them use as selfie cam the ultra wide camera zoomed.
