Power-Button not responding
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-12-2021 04:53 AM
Hi
I got the ZenFone7 Pro. Sometimes the power-button does not respond and cannot turn off the phone. The button seems to be ok, because the events I applied (double press or longpress) are working.
After a restart I can turn off the phone again. But I found no other way to get the power off working.
The updates are the latest available (29.14.53.23)
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-12-2021 05:49 AM
there is a software power button under the quick settings which you could use as a workaround till it gets solved
I also use on screen shortcuts to turn my screen off (Nova launcher has that possibility for example) to put less stress on HW PWR button
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-16-2021 05:19 AM
chris.roth.chI you have applied any other action than Power off to "Press and hold" then it's not supposed to turn your phone off. This is why we put a power button in the notification panelHi
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-14-2021 01:31 PM
Battery is fully charged . ASUS VivoBook will not turn on. Using power cord is only option to use laptop. Ideas?
