My Zenfone 7 Pro flip camera feels a bit off
Model Name: Asus Zenfone 7 Pro
Firmware Version:
Rooted or not:
Frequency of Occurrence: Quite often
This is about two things regarding the flip camera
1) Is it normal for the camera to be a put a bit closer to one side than the other on the phone's frame? Because my camera has a larger gap on one side than the other on the frame where it opens.
2) My camera also makes some odd noises when it closes and I know it's supposed to make some noise but I don't know if these are normal, can I get some personal help with it or something?
9 REPLIES 9
veeharish2005
Zen Master I
joseph.galea1922
  1. Model Name: Asus Zenfone 7 Pro
  2. Firmware Version:
  3. Rooted or not:
  4. Frequency of Occurrence: Quite often
Can you take any photo of the camera hinge area?
Tagion
Rising Star II
joseph.galea1922
  3. Rooted or not:
1. My flip camera also has a gap on one side, I guess it's because the motor is only on one side.
2. Check this thread: https://zentalk.asus.com/en/discussion/36458/flip-camera-make-terrible-sound-after-rotating#latest
veeharish2005
https://zentalk.asus.com/en/discussion/37733/my-zenfone-7-pro-flip-camera-feels-a-bit-off
Yes I can, as you can see there is a larger gap on one side of the camera than the other. That isn't normal is it?
lf_asus_z7p
Mine also has a difference of gap but not as big as yours. And mine also make a noise when it reaches the full close position and the full open position. It's looking for the max position i guess but this noise make the device look cheap, moreover when the module is not well centered in your case. Disappointing for that price range and moreover a "flagship" device.
