Charging led always enabled when USB is inserted
trailblazers
Model Name: Zenfone 7 Pro
Firmware Version: WW_30.41.69.143
Rooted or not: no
Frequency of Occurrence: each time
APP Name & APP Version: Led indicator
There is no way to permanently disable Led indicator when charging.
I disable the option and as soon as I connect the charging cable the option re enables itself and I have to manually turn it off.
Gustav_ASUS
Community Legend III
@trailblazers This is not the expected behavior. I'm going to send you instructions on how to generate a device log.
Check your Zentalk inbox.
fear_dot_com_20
Rising Star II
@Gustav_ASUS , how about an answer about the performance issue? Or the missing volte?
