A11 major problems with Gmail notifications
fear_dot_com_20
Rising Star II
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
After updating to A11 I started to see major issues with the battery optimizations, mostly on Gmail app, but once I started to investigate I see it overall. Email notification come with hours , if not tens of hours delay , which was not the case on A10. I noticed that even whether app is not updating in timely fashion.
It looks like phone goes to hibernate and not resumes for notification only once in a couple of hours if not more. Strangely but whatsapp is working fine. I have disabled all battery optimizations and I saw some improvements but not that good as in A10. Yesterday for instance, I lost a couple of important emails since they Gmail App only synchronized once in 10 hours....which is unacceptable.
Factory reset does not help since I have done it at least 7 times due to various issues since A11 update a week ago...
Please help!!!! I don't know what else to look for!
130 REPLIES 130
martin_stavinoh
Rising Star II
skipwoof
Hi
For me, I'm using that RSS app : https://f-droid.org/en/packages/com.nononsenseapps.feeder
And even without battery optimisations, I'm not receiving notifications. Can anyone else try ? On my girlfriend Nokia there is no issue with notifications for this app.
Regarding Google Calendar, I've updated to latest version... I will check on next days if it's fixed... as you are all saying. Thanks
I'll try that, I wanted to test this app but now I have another reason to do so 🙂 I'll report back how it went...
edit: I've just received several notifications from the app 😉
fear_dot_com_20
Rising Star II
My problems with gmail notifications are back. i have logged it and now I have sent the logs to Anders....let's see their reply.
skipwoof
martin.stavinoha87
https://zentalk.asus.com/en/discussion/comment/169063#Comment_169063
Arf... no notifications on my ZenFone 7 Pro for this app (even with battery optimisations disabled),
but the update for Calendar fixed the notification issues I used to had...
I'm really confused... 😓
fear_dot_com_20
Rising Star II
I can say that for me with all battery optimizations off, now everything seems to work. But I always reboot once I set those off. One more thing you can try is to disable battery optimizations for that app itself. Go to settings, apps and notifications , select the app you want then on battery select not optimized. This should fix your issue.
Try also a reboot once you did all thise steps from above
martin_stavinoh
Rising Star II
well my device has been up for almost 29days and notifications are still working even though Aggregator app which should inform me (if there was anything new) every 15mins (at XX:00, XX:15, XX:30 and XX:45) often delivers notification about 1-3mins later but that's much better than what it used to be (=no notifications at all)
I'm almost sure that rebooting now would be like playing russian roulette as exactly this happened to me in the past, it was working OK for many days but then I had to reboot and after some time notifications stopped working and I had to reboot twice a day sometimes and then it was again ok for days
