ZenFone 6 Timezone Brazil
digorochabh
Even if you do not want to use the time zone and manual time, the phone changes by itself. Please resolve this.
53 REPLIES 53
LP_ASUS
Community Legend I
Do you mean you haven't received the latest FOTA? Can you manually download the file and install it from here?
ZenFone 6 (ZS630KL) Driver & Tools | Phone | ASUS GlobalYou're looking for 1911.110 WW. A guide on how to complete the installation is here. https://www.asus.com/us/support/FAQ/1009748/
Once you install 1911.110, is your clock updating correctly?
neemiasvf
LP_ASUS
https://www.asus.com/Phone/ZenFone-6-ZS630KL/HelpDesk_Download/
No, we can't. It says that this update is to upgrade from Android 9 to 10 only. Since this problem happens on Android 10, we can't update it.
brunofracalossi
@neemiasvf I just followed the steps and updated it in my android 10... It worked perfectly.. just follow the steps mentioned by @LP_ASUS
edallagnol
LP_ASUS
The manual update solved the issue, thanks!
LP_ASUS
Community Legend I
neemiasvf
https://zentalk.asus.com/en/discussion/comment/36815#Comment_36815
That means if you want to upgrade from Android 9 to 10, you need to be on 1909.194. If you are already on Android 10, you can ignore that line. This is a sequential Android 10 update for all users already on Android 10.
