Zenfone 6 Power and volume menu alignment mismatch.
djcsweet16
I've updated my zenfone 6 to android 10 a couple of days back. I've noticed that while pressing volume buttons, the sliders appear near the power button and while pressing and holding the power button, the power menu appears near volume buttons. It's just a design flaw. But it's definitely wierd. Hope to see a fix in upcoming update.
11 REPLIES 11
djcsweet16
Anders_ASUS
This is by design and nothing is wrong
  1. Volume settings are in level to give easy access without any need to change your grip
  2. Power buttons are in level to make it harder to press power off or restart by mistake
Alright then!
_jis_
Zen Master III
Anders_ASUS
This is what I thought of as a possible explanation of how a developer would think if he wanted to prevent unwanted problems.
I understand, ok.
