11-09-2019 09:03 PM
12-21-2019 09:06 PM
12-22-2019 01:11 PM
tarun.bhatia026Finally, someone came up with something specific. For example, I do not use wi-fi at all, exceptionally, which may explain that I have no battery problems.I have a zenfone 5z, updated it to android 10 last week. Since the update battery is draining within 6-8 hours and the battery usage shows no such app or system app that is draining that much battery. The only solution i could come up with is turning the wifi off (the flat line in the screenshot is when the wifi was turned off). But a smartphone becomes pointless without wifi. So I am hoping they would fix this issue with the next update.
12-23-2019 06:04 AM
Tanmay hegdeAm having Asus 6z not Asus 5zhttps://zentalk.asus.com/en/discussion/comment/33327#Comment_33327
No bro after updating to android 10 the battery is life is worst even after having the good habit of charging and regular usage...
12-23-2019 06:06 AM
tarun.bhatia026Bro I have Asus 6z ... After update I having problems....I have a zenfone 5z, updated it to android 10 last week. Since the update battery is draining within 6-8 hours and the battery usage shows no such app or system app that is draining that much battery. The only solution i could come up with is turning the wifi off (the flat line in the screenshot is when the wifi was turned off). But a smartphone becomes pointless without wifi. So I am hoping they would fix this issue with the next update.
12-23-2019 06:07 AM
tarun.bhatia026I got update bro ... But there is no updates about battery... So there is no improvement in battery life...I have a zenfone 5z, updated it to android 10 last week. Since the update battery is draining within 6-8 hours and the battery usage shows no such app or system app that is draining that much battery. The only solution i could come up with is turning the wifi off (the flat line in the screenshot is when the wifi was turned off). But a smartphone becomes pointless without wifi. So I am hoping they would fix this issue with the next update.
