When volume is high, it keeps re-adjusting to a lower volume
jrmhng
Model Name: Zenfone 6
Firmware Version: WW_17.1810.2011.183
Rooted or not: No
Frequency of Occurrence: Almost always
APP Name & APP Version (If your issue relates to the app): None / system wide / for all apps which play media
When I play anything at a loud volume, within seconds or minutes, it will automatically be lowered. I have tried turning outdoor mode but that doesn't help. It is always lowered to the same point. This is regardless if it is Youtube, Spotify or any app which is playing media with sound. This is also through both the phone loudspeaker or say to a Bluetooth speaker.
For the volume, I have the following settings:
Sync volumes - on
Smart volume - off
Outdoor mode - both on or off will have this issue
AudioWizard - normal
Thanks for reading.
Monark
Zen Master I
Did you tried with sync volumes off?
jrmhng
Monark
Sync volumes is for notifications and call volume. I can try. Thanks.
VS-KR
And have you got any accessibility or developper feature enabled ?
What specifically should I be looking for in this?
