Tip to improve battery life and SOT on z6 by changing one simple setting.
gouravjoshi100
Rising Star I
I am getting 2more hrs of SOT and around 5hrs mmore standby by doing below. have not seen any impacted on any function.
Goto setting ---advanced---mobile manager--data usage---control app data usage---google play services---uncheck backgroud data usage and uncheck for wifi as well if u use wifi a lot @CH_ASUS @anderlai57 @Anders_ASUS
12 REPLIES 12
misc_mukund
Can't find Google play services under the place you said. All other apps are there except this.
Karim
misc.mukund
Same
gouravjoshi100
Rising Star I
@Karim @misc.mukund surprise...are u checking on correct location..check my screen
Karim
Yes nothing about Google mobil and WiFi as well
