Power menu takes a bit more time than normal
girishsonu2000
Rising Star II
Power menu in other phones usually pop up when we keep pressing power button for 2 seconds
But after the update in which power menu style changed now it usually take about 4 seconds
Isn't it a bit longer
5 REPLIES 5
prashanth
Rising Star II
girishsonu2000
Im on .119 too,it takes 2 seconds for me......is this happening every time?
_jis_
Zen Master III
@girishsonu2000 Then you probably have a problem with your installation. Try clearing all applications' cache. BTW Did you upgrade from a complete 1.9GB update file or did you use only small differential 122MB OTA file?
I'm on the latest 119 too, it takes 2 seconds for me for any Asus color power menu style and 1.5 seconds for default system power menu when pressing power button.
But I don't use the Power button at all for this purpose, I defined a special gesture in the FNG application, where the menu appears without delay.
evnchn
Rising Star II
Typical long-click actions such as long-click on volume button until volume go up continuously, long-click on smart key, long-click on multitask button and take screen shot, they all take 1 second. Apparently the power menu takes 2 second, maybe counted the long-click it twice on the firmware?
girishsonu2000
Rising Star II
_jis_
I am also on latest version through that 122mb OTA file.
BTW which gestures you are talking about, any external (3rd party) application?
