No audio on connecting headphones
ZT-afc54f14
Hi all, I have been facing this issue since months. Whenever I connects headphone/earphones via headphone jack or Via Bluetooth, It always happen that out of 5/10 times, There will be no sound output through the headphones. For fixing it, I have to restart everytime it happens. Headphone connected icon shows in the status bar. Only the output is not coming. Please give a software update to fix this as soon as possible.
victor010
Zen Master III
Hi, kindly help us with the following information to find a solution to your query.
1.  Name of the Asus device you are using.
2.  Firmware version your device is on.
Hi, we'd request you follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue
factory reset your phone after taking a full backup : https://www.asus.com/support/FAQ/1006346/
