Microphone issue Android 10
joefu12
After upgrading to Android 10 the microphone during a call does not work. The caller can hear me when I use the speaker phone. Call also functions normally after I turn off speaker phone. I have to toggle it on and off for caller to hear.
Sorry if my explanation is bad...
8 REPLIES 8
joefu12
Discovered another issue... the receiver/earphone doesn't work as well after a 2nd call.
LP_ASUS
Community Legend I
Can you back up your data and factory reset the phone? Sometimes a big software update can be smoothed out with a reset.
If you still have issues with the receiver after a reset, I recommend contacting your local ASUS repair center.
joefu12
Dang that's a really annoying way to see if it'll work... I'll try when I have time to re do everything. I just got this phone last Friday....
trabink2
I have exactly you same issue, my microphone does not work... I did reset my phone, Asus Help please!!!
