LED light not reflecting actual battery status as fully loaded in case of charging limit
superniiice
Model Name: ZF6
Firmware Version: ...132
Rooted or not: rootless
Frequency of Occurrence: persistent
APP Name & APP Version (If your issue relates to the app): System apps for display and battery care
If charging limit is set to e.g. 90% and LED notification is activated, there's no green light as soon as 90% battery status has been reached.
May I ask whether this behaviour is as expected. Many thanks
Monark
Zen Master I
For now the led will lit only when it is 100% not for any other even if you set the limit to either 80% or 90%
superniiice
Monark
Thanks a load for the clarification. Nevertheless, you may agree that any set and reached limit shall lit the led.
Anyways, that's whining at a high level! 🙂
