Issues that needs fix
kooldude7285
Rising Star II
1. Auto rotation sometimes doesn't work
2. Front camera opens directly when you get video call becomes an issue if in pocket
3. when in call you cannot go to any other screen. screen stays locked on call screen.
4. Auto brightness sometimes doesn't work
5. Free ram is around 1gb which does not look good i have honor 10 with 6gb ram and always get 2.5gb free ram. i don't think optiflex is problem because i already have it off.
6. Low light camera is not up to the mark when compared with other camera with same specs
7 Slow motion 480fps looks below average and are we getting 960fps considering the chip it has.
8. Struggles with with focus when taking macro shots whereas other phones with same lens can handle it much better.
9. There is no option to have multiple users profile.
10. Option to change clock position.
11. Battery life could be better its great though.
12. Camera gets foggy sometimes automatically due to moisture i guess and it happens from inside the lens.
these are few i experienced others can add if any so that asus can fix them. Ear piece lil better now but not sure if it will be updated any further.
51 REPLIES 51
aarkayy31
midwej said:
2. After cca 30 days using the AccuBattery, my estimated capacity is 4650 mAh. Is this value correct?
It can't be. Battery doesn't degrade that fast. Asus has promised the battery to be around 4500mah even after 2 years which is 10% degradation.
midwej
There is my AccuBattery + I'm using original cable and charger: https://imgur.com/aLUoJCU
aarkayy31
I guess accubattery is just inaccurate in this case?
midwej
This is good question. And this is the reason why I share my stats. I would like to know the stats from another users or obtain the answer from ASUS. There is also one thing: the rated capacity (I guess real capacity) is 4850. And based on my reading in another discussions, It can be software limitation or recharge reserve:
1. https://forum.xda-developers.com/galaxy-s10/help/low-estimated-battery-capacity-t3909380/post7951618...
2. https://forum.xda-developers.com/s10-plus/help/accubattery-accurate-t3911419/post79124166#post791241...
_jis_
Zen Master III
You probably don't know or use AccuBattery app in person. After using AccuBattery for just 30 days its result on Health tab is not about lost battery capacity, it is about more accurate capacity estimation. If midwej has 4650mAh it is pretty normal, other users on XDA measured the same: 93-94% 4649mAh and 94% 4690mAh.
Try AccuBattery on your ZF6 a post your result here.
For example I measured 95% 4747mAh on my ZF6, but I treat my battery in a special way (50% ~ 90%).
