07-08-2019 10:19 AM
07-14-2019 08:10 PM
yes it indeed but it happens rarely but not a good experience. Request you to put a picture next time you get the same so mods believe us. i couldn't get one as the 1st tym it happened i thought i scratched my lens.. lol.. so out of shock i forgot to capture..Kamesh said:Anders_ASUS said:1. We know about this issue and it will be solved.kooldude7285 said:1. Auto rotation sometimes doesn't work
2. Front camera opens directly when you get video call becomes an issue if in pocket
3. when in call you cannot go to any other screen. screen stays locked on call screen.
4. Auto brightness sometimes doesn't work
5. Free ram is around 1gb which does not look good i have honor 10 with 6gb ram and always get 2.5gb free ram. i don't think optiflex is problem because i already have it off.
6. Low light camera is not up to the mark when compared with other camera with same specs
7 Slow motion 480fps looks below average and are we getting 960fps considering the chip it has.
8. Struggles with with focus when taking macro shots whereas other phones with same lens can handle it much better.
9. There is no option to have multiple users profile.
10. Option to change clock position.
11. Battery life could be better its great though.
12. Camera gets foggy sometimes automatically due to moisture i guess and it happens from inside the lens.
these are few i experienced others can add if any so that asus can fix them. Ear piece lil better now but not sure if it will be updated any further.
2. in what app? It doesn't happen with messenger and many other IM apps. Even if it tries to open or close, it will automatically shut down without taking damage but I agree, it would be best if it didn't flip in/out at all.
3. This works without problem with my Zenfone 6. If you mean before you have answered, then this is normal Android Pie behavior. We're running close to stock Android.
4. Your adaptive brightness will learn with time. Just keep adjusting the brightness whenever it's wrong.
5. It's no issue to have 1gb free in android. It doesn't mean that you won't have enough ram when it needs it. If you wan't to see a larger amout of available RAM, then you can go into Auto-start manager in the Powermaster app and turn it off and on again. This will temp clear your ram.
6. Which camera are you comparing with? We're improving the camera with every update and I would say we're already on par with similar priced phones with the same camera sensor and in some scenarios, even better.
7. We're working on improving the sharpness with 480fps. I can't disclose anything future plans regarding 960fps
8. What other phones are using the exact same lens? All lenses are different with different characteristics. A tip is to keep it at a distance where you can focus and then zoom. With good lighting it will use its 48mp capability to make that shot as crisp as with a macro lens. Use a 2s timer to reduce shake during capture
9. I have to check why we made this decision.
10. This is a change from Android Pie but I've sent the feedback to our SW developers.
11. Haha, battery life can always get better
12. I tried to get the lenses on my Zenfone 6 to fog up by blowing humid breath into one of the holes in the camera module but they stayed clear. This is the first time I've heard about this issue.
12 .yes the fog in lens is true even i have somehow dust particles in the lens don't know how the got inside .
07-15-2019 10:53 PM
auto rotate is the main problemAnders_ASUS said:1. We know about this issue and it will be solved.kooldude7285 said:1. Auto rotation sometimes doesn't work
07-19-2019 02:24 AM
2. this shouldn't happen. The near field sensor prevents the camera from flipping out.kooldude7285 said:Thanks for the response. Really appreciated. Please find further comments.Anders_ASUS said:1. We know about this issue and it will be solved.kooldude7285 said:1. Auto rotation sometimes doesn't work
1. Sorted
2. In whatsapp this has happened many times and my only concern is this will affect camera module if kept on flat surface. Request you to fwd the concern further.
3. Yes before answering the call. I know its by default PIE behavior but can we make it work given sometimes you don't want to pick the call but still need access to other apps. You know there are times 😛
4. Sorted
5. Looks ok now.
6. Oneplus 7 is the main contender for Asus 6Z. i know software implementation is different on both but i feel 6z could do much better.
7. Sorted. 960FPS should be provided looking at the capability of Processor.
8. Ok but macro means i should able to get closer although its not a macro lens but i am able to do much better with my other phone. If i am going to keep at a distance i will miss on details and zoom doesn't help either. I just hope you get some optimization done so its able to focus with best of its capability.
9. This is a default feature since marshmallow i guess. Please get it back.
10. ok
11. Hope it gets with software update.
12. Although i missed taking photo of the same but here is the video from youtube reporting the same. It goes away after 10mins but it will ruin the video experience.
https://youtu.be/o9LXTaFs300
13. Can we have Level 3 support for Camera2API?
14. Earpiece is better now not the best. Is it going to get better?
15. Animation issue in file manager.
https://us.v-cdn.net/6031231/uploads/editor/fd/vmgllj31cevb.jpg
16. Screen flickering issue experience last night. I tried recording it but it did not captured flickering.
Thanks again for the response its a great phone and we want it to be the best in its segment.
07-19-2019 07:33 PM
Wide viewing lenses are generally better at focusing on objects that are close than the main view lenses. This is why some phones use the wide viewing lens both for wide view and macro. Even if you can get closer with our wide view lens, it doesn't look better. This is's something we can fix with software. The best way to take marcos with the ZenFone 6 camera is to use the main camera with 8x zoom and 2s delaykooldude7285 said:Hi there... the fog issue came again i dint had extra phone to capture the same. but i have noticed when its not able to focus for a long time the lens gets foggy and it happens with just one lens. Also why is it that wide angle lens focuses much better when closer to subject whereas main camera couldn't. thats where macro shots get affected when we are not able to move closer like we can on oneplus 7.Here is the video. Another thing in pro mode EV cannot be adjusted with ISO and SHUTTER speed. EV will reset to zero if iso or shutter is adjusted.Anders_ASUS said:1. We know about this issue and it will be solved.kooldude7285 said:1. Auto rotation sometimes doesn't work
07-19-2019 07:34 PM
