Issue with cellular network data connection lost
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-06-2019 01:54 PM
Dear ASUS, I've found a problem which happens when my Zenfone 6 leaves Wi-Fi area. It lost possibility to use cellular network data connection (same time voice calls work fine).
The only ways to solve the problem is not to reboot a device or enter/exit an airplane mode BUT to remove SIM card via working phone and put it back OR to change network type to 2G/3G and back to 2G/3G/4G
Zenfone 6 Edition 30, WW_16.1220.1909.193_0, Vodafone (HU)
Any ideas why it happens and how to solve it without service center? Thank you in advance...
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-06-2019 02:20 PM
Probably it is the Vodafone/UPC network problem, not the phone /// but anyway check it if possible.
PS: thank you for the Edition 30. It simply amazing device. Last time when I felt the same huge like sense to device was in 2001 to one of Motorola phones :))) Designers are genious
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-07-2019 03:00 AM
What APN settings are you using? Vodafone have recently changed their settings in some countries so double check if you have the right ones
You can also try going to developer settings and enable Mobile data always active which you find under Networking. This will drain the battery a little bit.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-07-2019 12:41 PM
APN setting as it recommended by operator Vodafone HU for prepaid users vitamax.internet.vodafone.net
It seems that this problem appear just on some devices. For example my old Zenfone 5Z is works fine but Zenfone 6 and some iPhones not OK.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-08-2019 06:40 AM
If this is the case, then it sounds like you need Vodafones help. Please let us know if there's anything we can do
