03-22-2020
11:55 PM
- last edited on
01-16-2024
01:31 AM
by
ZenBot
03-23-2020 07:18 AM
psnandroid21Do one thing send your logs to @Anders_ASUS and they will determine what the problem is and then u can take whatever steps requiredhttps://zentalk.asus.com/en/discussion/comment/50592#Comment_50592
Restart is only a temporary fix right?
It will come back again.
Will a reset solve the problem once and for all?
03-23-2020 08:58 AM
psnandroid21I will PM you with instructions to check if you're having the same issue. If you are, then it will be fixed in the next FOTAhttps://zentalk.asus.com/en/discussion/comment/50592#Comment_50592
