03-12-2020 04:08 PM
03-23-2020 12:13 AM
Anders_ASUSThe is charging fine as it should be after I bought new charger and adaptor, but the phone acts up weird as in when on charging mode it makes sound of attaching cables. No heating isuue whatsoever. I would appreciate if you relay on to developers to push quality updates with bug fixes and all details in the description. I have seen OTA without any description which makes no sense to update.Ok, so just to make sure. When you're charging your phone, is it hot, or is it very hot in your environment? Do you see the two plus signs above the battery when charging?
Have all of you tested with more than one cable (preferably a new one) to rule out that the original one might be broken.
03-23-2020 09:10 AM
krangtzenNew ASUS charger or 3rd party? It shouldn't make sounds like that. If you want, we could log your device and when you hear this sound, please note the time and generate a log that we can have a look athttps://zentalk.asus.com/en/discussion/comment/49438#Comment_49438
Thanks
03-23-2020 01:59 PM
03-23-2020 06:55 PM
03-25-2020 08:00 AM
