Charging time taking too much
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-26-2019
09:27 PM
- last edited on
01-16-2024
01:53 AM
by
ZenBot
Specially for last 10% it is taking more than 45-60 minutes ,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-03-2019 09:46 AM
CH_ASUSMy problem is asus max pro m1Are you using the bundled Asus charger and cable?
Also after charging, restart and try again.
I assume this charge time is even when you are not using the phone actively.
Another note, did you also notice the device heating up more than usual? Could it be that some app has bugged out in the background using cpu/battery - and as a result also impacting charging.
And asus 6z taking same time to full charge
That's why I am asking , you see my screenshot if it was unusual you inform me i will rush to nearest service centre
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-05-2019 05:39 AM
sivamani242Which is also why I am asking if you are charging the ZenFone 6 using the ZenFone 6 bundled charger.https://zentalk.asus.com/en/discussion/comment/31969#Comment_31969
Or are you charging the Zenfone 6 using the Max Pro-bundled charger?
Also do you notice device get particularly hotter (than before)? (Thinking if any app is stuck in the background also draining battery causing device heat up and slower charge).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-05-2019 06:46 AM
CH_ASUSI am using zf6 charger only for charging for my zf6 , i think no app was running , but i can say that sometimes wifi is turning on automatically, withouth mannual switching on wifi, it was taking 2hours 21 minuteshttps://zentalk.asus.com/en/discussion/comment/32014#Comment_32014
While asus max pro m1 with asus max pro m1 charger taking 2hours 25 minutes ,
Previously i used max pro m1 i had given that mobile to my friend
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-06-2019 02:03 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-29-2019 07:30 PM
- « Previous
- 1
- 2
- Next »
