01-17-2021 04:42 AM - last edited on 01-16-2024 02:07 AM by ZenBot
01-17-2021 11:03 PM
01-18-2021 04:06 AM
01-18-2021 07:27 AM
01-18-2021 07:28 AM
01-22-2021 07:23 AM
skylerwolfeIt could be that the difference you're seeing is because you're comparing to 100% charge on A10 and you're now only charging to 80%. The battery percentage is not linear with the actual amount of power in the battery. It's more of a good estimate. In a perfect world 80% would mean 80% but in reality all batteries are different and the code is based on an average battery. So to find out if there's any difference, you need to charge it to 100%. Leave the charger connected for another 20 minutes even after the battery has reached 100% to make sure it's charged to its maximum capacity.I'm on 107 and curious what others are getting overnight. I seem to lose about 1% per hour. I know A11 is still new and this may improve over time. With A10 I think I usually lost about 2% while sleeping instead of 7-8%. It's not bad enough at all for me to consider doing a reset of the device, unless everyone else is getting clearly better results.
Battery Drain Over Night on A11
