12-20-2019
06:28 PM
- last edited on
01-16-2024
01:49 AM
by
ZenBot
12-25-2019 02:57 AM
_jis_Using same chargers I was using on pie. I have chargers in 2 vehicles, at work, in the kitchen, basement, living room, bedroom so no I don't use the factory charger everywhere. And as I mentioned I try to avoid fast charging. Don't you think if I had known this fact before making the OP I would have posted it? All those chargers worked before and should work now lol (and do work other than the led not staying on).Huh. Please next time post these important details in OP. So you don't use original charger and cable, right?
12-25-2019 04:11 AM
12-25-2019 04:56 AM
_jis_Understood lol. I didn't think to mention it likely for the same reason nobody else that tried to help asked for that detail. Merry Christmas.All those chargers worked before and should work now lol
I agree, I also use many different chargers, the original Asus I use at home, I use another non-original QC3 at work, I also charge from different laptops I have at home and at work. However, nowhere do I have your problem, the charging LED shines as it should for the entire charging period (unless the Battery Care is On, charging takes place within the set time period in Battery Care options and battery capacity reached 80 ~ 81%). So it is not an issue that affects everyone.
Unfortunately, it is normal here that an error is often reported in one sentence, but the conditions under which the error occurs are'nt specified. This is always very important, such as system version, use of original components or others, use of cover / case / screen protector, unlocked bootloader, root, changes in Developer options, nonstandard Launcher, Dialer, ...
I don't want to criticize you, because it will happen to me sometimes. I myself forgot to mention in another thread that I use Google Phone - Google Dialer when someone complained about the default Asus Calling screen and I argued that it works fine for me.
When something is not working for someone and it works for another user it is always very laborious to find out why this is so, why the experience is so different. Because of those possible differences between configurations, there are so many.
01-02-2020 01:14 PM
chen.saosao1. 如題, 剛插進去是會亮, 大概十幾秒後就會熄滅
2. 燈不亮, 但是充電正常
3. 訊息來, 燈是正常會亮, 只有充電不亮
4. 更新完系統就發生這個問題
充電時手機led指示器不會亮
01-09-2020 02:36 PM
