Audio wizard problem
bulurox
If I toggle the equaliser while listening to music , the sound is cut off in the earphone. I have to unplug and then replug the earphones .
11 REPLIES 11
bulurox
johnCforVTS
I tried to toggle the wizard with pluged earphones as you said and worked fine for me. I guess you are unlucky...
A simple reset fixed it
ravitejavooka
Even I am also facing the same problem...What is the solution?
sharanknataraja
Try to change ringtone volume in setting., Then audio will come back(temporary fix)
ravitejavooka
No change brother .. ...
bulurox
ravitejavooka
Factory Reset seems to be the final resort brother.It fixed mine
