ANDROID10 Battery draining notification
Krish
Rising Star I
this thing keep coming
5 REPLIES 5
aarkayy31
I had to restrict it in the settings. It caused some serious battery drain issues.
Krish
Rising Star I
aarkayy31
how u restricted that?
aarkayy31
i think you get the option to restrict it when adaptive battery gives you the notification like the one you have right now. Try clicking on it or something, you should be able to find it.
I don't know the exact consequences of this though. Personally I did not face any issue after restricting it, but I was planning to factory reset my phone once the closed beta ended anyway since only a minority of users seem to be affected by this.
Krish
Rising Star I
aarkayy31
this notification keep coming evenafter stopping many times, finally I turned off battery draining app notification
